yo Tjg,
Re; "had to replace a rubber hose for the air injection system just in front of the cat (I wasn't sure if this caused the bad cat or if the bad cat caused the old hose to melt (any insight would be appreciated immensely)).."
Someone may have replaced the metal tube w/ the rubber hose, which would def melt.
Is this Air Inlet Tube that melted? See #4 9J454 Air Inlet Tube
by Ford via thedieselstop.com
or @ PCI Inc;
Ford Air Tube
Replaces O.E. E6TZ-5F235-B
Use with #7 clamp.
Use with #39 valve
$28.14
http://www.pciinc.com/images/53.jpg
Ck all air sys Vac Lines first & since you obviously know the system, I'll skip the overview for now.
Next is did you do both KOEO & KOER portions of the test with engine @ Normal Operating Temperature before doing KOER?
DTC 311,
312, 313 & 314; "...311 and 314 indicate the Secondary Air Injection system is inoperative.
DTC 312 indicates that Secondary Air is misdirected. DTC 313 indicates that Secondary Air is not being bypassed when requested. Possible causes: Visually inspect
vacuum lines for disconnects in the AIR system. Visually inspect for proper vacuum line routing. Refer to
VECI decal. Visually
inspect Air Pump for broken or loose Air Pump Belt. Refer to Section 13A for adjustment/replacement..." READ MUCH MORE
Source: by Jim at
http://www.justanswer.com/questions/sqj6-trouble-codes-fo-1995-ford-f150DTC 312 Secondary Air Injection (AIR) misdirected during
KOER Troubleshooting
ATTEMPT TO ELIMINATE
DTC 312
Disconnect vacuum line on
AIRD valve (or left AIRB2 valve on 7.0L) and cap vacuum line. Miesk5 NOTE; Thermactor Air Diverter (TAD) Solenoid
(AIRD)
Location pic in a 96 (AIRD) by Ryan M (Fireguy50) at fordfuelinjection.com
Key off.
Repeat Engine Running Self-Test and record service codes.
Is DTC 312 present?
Yes system ok EEC system OK. REFER to Diagnosis index in Section 13A.
No GO to KC5 .
KC5 CHECK AIRB AND AIRD SOLENOIDS ELECTRICAL OPERATION
DVOM on 20 volt scale.
Enter Output State Diagnostic Test Mode (DTM). Refer to Section 5A , Quick Test Appendix.
Disconnect AIRB solenoid.
Connect DVOM positive test lead to VPWR circuit and negative test lead to AIRB circuit of AIRB vehicle harness connector.
While observing DVOM, depress and release the throttle several times (to cycle output On and Off).
Repeat for the AIRD solenoid.
Does each solenoid circuit cycle 0.5 volt or greater?
YES GO to KC6 .
NO REMOVE jumper. GO to KC10 .
KC6 CHECK AIRB/AIRD SOLENOIDS FOR INTERNAL VACUUM LEAKS
Remain in output state DTM.
Reconnect AIRD/AIRB harness connector.
Vacuum pump connected to the supply port and vacuum gauge connected to the output port of one solenoid.
Apply 15 in-Hg (51 kPa) vacuum and observe gauge.
Repeat steps above for the other solenoid.
Does vacuum gauge reading hold for each solenoid?
Yes GO to KC7 .
No REPLACE AIRB/AIRD solenoid assembly. RERUN Quick Test.
KC10 MEASURE AIRB/AIRD SOLENOID RESISTANCE
Key off.
Disconnect both AIRB/AIRD solenoid connectors and measure both solenoid resistances.
Is each resistance between 50 and 100 ohms?
Yes GO to KC11 .
No REPLACE AIRB/AIRD solenoid assembly. RECONNECT both solenoids. RERUN Quick Test.
KC7 CHECK AIRB/AIRD SOLENOIDS FOR VACUUM CYCLING
Continue in output state DTM.
Install vacuum pump to the AIRB solenoid vacuum supply port and install a vacuum gauge to the AIRB output port.
Apply 15 in-Hg vacuum.
While cycling outputs On and Off (by depressing and releasing throttle), observe the vacuum gauge at the output.
Note: Re-apply vacuum between cycles.
Repeat for AIRD solenoid. Connect vacuum pump to the AIRD solenoid vacuum supply port and connect a vacuum gauge to the AIRD output port.
Cycle output on and off.
Does each solenoid cycle vacuum output on and off?
Yes EXIT Output State DTM, RECONNECT vacuum hoses. REFER to Diagnosis Index in Section 13A.
Key off.
YES go to KC11 .
NO REPLACE AIRB/AIRD solenoid assembly. RECONNECT both solenoids. RERUN Quick Test.
KC11 CHECK CIRCUIT CONTINUITY
Key off.
Disconnect Powertrain Control Module (PCM). Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary.
Install breakout box, leave PCM disconnected.
Measure resistance between AIRB circuit at breakout box and AIRB circuit at vehicle harness connector.
Measure resistance between AIRD circuit at the breakout box and AIRD circuit at vehicle harness connector.
Is each resistance less than 5.0 ohms?
YES GO to KC12 .
No SERVICE open harness circuit. REMOVE breakout box. RECONNECT PCM and both solenoids. RERUN Quick Test.
KC12 CHECK FOR SHORT TO GROUND
Key off.
Breakout box installed, PCM disconnected.
Disconnect both AIRB/AIRD solenoids.
Measure resistance between AIRB circuit at the breakout box and Test Pins 40, 46 and 60. Measure resistance between AIRD circuit at the breakout box and Test Pins 40, 46 and 60 at the breakout box.
Is each resistance greater than 10,000 ohms?
Yes GO to KC13
No SERVICE short to ground. REMOVE breakout box. RECONNECT PCM and AIRB/AIRD solenoids. RERUN Quick Test.
KC13 CHECK FOR SHORT TO POWER
Key off.
Both AIRB/AIRD solenoids disconnected.
Measure resistance between AIRB circuit at the breakout box and Test Pins 37 and 57. Measure resistance between AIRD circuit at the breakout box and Test Pins 37 and 57 at the breakout box.
Yes REPLACE PCM. REMOVE breakout box. RECONNECT both solenoids. RERUN Quick Test.
No SERVICE short to power. REMOVE breakout box. RECONNECT PCM and AIRB/AIRD solenoids. RERUN Quick Test. If DTC is present, REPLACE PCM.
Oxides of Nitrogen readings. Oxides of nitrogen (NOx), including nitric oxide (NO) and nitrous oxide (NO2), are formed if the combustion temperatures within the combustion chamber exceed some 2,500°F. This can occur when the engine is under load. When excessive temperature conditions exist, the greatest amount of NOx is typically produced at the stoichiometric point (AFR 14.7 or Lambda of 1.0) as the engine is under a light load. If the combustion process within an engine is burning fuel at or near stoichiometric point, NOx levels on acceleration will typically read significantly higher than those measured at cruise and during deceleration. Typically, the NOx readings at idle will be 0 PPM.
High NOx Readings. Circumstances that can lead to abnormally high NOx emissions are:
Malfunctioning EGR valve
miesk5 NOTE; since there are no EGR valve codes; let's skip this for nowLean fuel mixture (AFR above 14.7, Lambda above 1.0)
Improper spark advance
Thermostatic air heater stuck in the heated air position (miesk5 NOTE; prob for a Yugo...)
Missing or damaged cold air duct (miesk5 NOTE; I think this is the large tube dangling under jack area on pass. side, it is for the smog (air) pump and goes to da filter cannister then to pump...)
Combustion chamber deposits
Malfunctioning catalytic converter
NOTE. Catalytic converter intervention and NOx concentrations
High NOx readings at the tailpipe are an clear indication that there is a problem in at least one part of the system, but a NOx reading that appears within "normal" ranges or is only modestly elevated is not necessarily a reliable indicator of proper or even acceptable system performance. NOx readings at or near "normal" are possible, and not uncommon. From a malfunctioning engine equipped with a properly functioning catalytic converter. In such circumstances, truly elevated pre-catalytic converter NOx levels will be masked by the catalytic converter and the potential for an NOx problem must be further evaluated in the context of other readings of abnormal gas concentrations and AFR/Lambda readings.
Mini-Tube Vacuum Hose Service in Climate Control System in a 96; "...Measure the length of the damaged area of the mini-tube vacuum hose. Cut a piece of standard 3mm (1/8-inch) ID vacuum hose approximately 25mm (1 inch) longer than the damaged area of the mini-tube vacuum hose. Cut the mini-tube vacuum hose on each side of the damaged area and remove damaged portion of the mini-tube vacuum hose. Dip the mini-tube hose ends in Tetra Hydro Furan (THF) or Methyl Ethyl Ketone (MEK). Either of these solvents will act as a sealer for the repair of the mini-tube vacuum hose. Insert the ends of the mini-tube vacuum hose approximately 9mm (3/8 inch) into the ends of the standard 3 mm (1/8-inch) ID replacement vacuum hose. Shake the service joint after assembly to make sure solvent is dispersed and vacuum line is not blocked internally. Test system for a vacuum leak in area serviced..." from 1996 F-150, F-250, F-350, F-Super Duty and Bronco, F-Super Duty Motorhome Chassis Workshop Manual
Source: by Ford
Vehicle Emission Control Information
(VECI) Decal, Vacuum Diagrams & Calibration Parts List for 88 & UP. On-Line for Free at Ford. Click "Quick Guides" in left panel; Scroll to & CLICK VECI Labels "Provides Vehicle Emission Control Information (VECI) and a related calibration parts list." Enter applicable info (need to know your Calibration number from your B-pillar sticker).
Vacuum Diagram is the same as the one on the core support or hood or air filter cover
Source: by Ford motorcraftservice.com http://www.motorcraftservice.com
