Help with brake lights?
hazzs79
Does anyone know how to help me? I have no brake lights I have changed everything new brake light switch, new turn signal switch, new flasher, new bulbs and fuse, but I still have no brake lights. Please help.
BLADE262US
Michigan
Do you have a ground ?? If you take the tail light out of the box you should see where one of the wires is screwed to the body make sure thats hooked up . You could take a meter and check from one of the bulb terminals to the body to see if you have a loss of ground in the harness somewhere . Power goes from the fusebox to the brake light switch to the lights in back so you could start at the switch you should have 12 volts on one side of it then when you push the brake pedal down you should have 12 volts on the other side if so then follow it back there must be a break in the wire if its not at the bulbs after that . :D /emoticons/[email protected] 2x" width="20" height="20" />
Sandoval_broncosauria
