help with a few problems of a bronco i may buy
P
paintballdude902
eastern north carolina
yard ur forgetting the new axles oh and since its still got the original tape deck in it a new cd player.....maybe a new set of speakers....oh and since im doing speakers i should add a p.a. and a 2 new mufflers so it sounds cool then i should probably paint it... heck ill do a nugent and paint it like a zebra oh and rhino line the under side to prevent rust
god dang it i know too many jeep drivers
fire- i just keep thinking that as soon as i buy it im going to find a better deal. but i probably will find cheaper but i doubt in this condition i like the fact that it was a company car so i know that the maintainance was up to date and he has the records
BB33's
Rancho Cucamonga CA
Maintence Records can tell alot about about the truck other than just when services were done, but also things like if it had reocurring problems and what you can expect to fix if parts haven't needed servicing in the past. The guy I bought my truck from was a Ford Service Advisor and with my truck I got a three ring binder full of service records and receipts. sorry got a little off topic.
BB33's
Rancho Cucamonga CA
Hey paintballdude! I was looking over some Ford TSB's (technical service bulletins) and found one issued on 23, September 1996-
ISSUE- Roof cracks or rusts at or near end of drip rail at B pillar
ACTION- Repair roof sheet metal using specified FORD factory repair kit
PARTS- 0ne(1) Reinforcement panel- Body panel RH
0ne(1) Reinforcement panel- Body panel LH
0ne(1) Reinforcement panel- Roof panel RH
0ne(1) Reinforcement panel- Roof panel LH
Two(2) Roof side rail enforcement
0ne(1) 2 part Epoxy
Fourteen(14) Rivets
1 Instruction sheet (I.S. sheet #6661
I don't know if it is still available but it did list a part number F5TZ-98023-A
P
paintballdude902
justshootme- the guy at the dealership today told me to come back tomorrow when the manager is in
i doubt it will be but maybe i will get lucky
crazyhorse85
clarksville,tenn
Hey paintballdude according to my ford parts catalog F5TZ-98023-A is obselete can't get from ford anymore...you might check vintage auto parts or lmc truck catalog...That's were i got my quarter pacth panels from..... B)
PJR351W
Well it sounds like a great deal to me, the rust isn't an issue if you know how to weld or use bondo after your prep work, The gear selecter is going to need a new cable most likly LMC Truck has all the parts for that, The manifold is questionable depending if it is exhaust or intake but either way YES they are easy fixes you can fix if you have a mechanical background, The turn signal switch is an easy fix, take the steering wheel off and replace the switch, the switch is held in by 3 Philip head screws, and the RPM are correct if there is no over drive on the trans,2900 to 3100 is your high way speed. You can install an over drive system on the trans if you want to save fuel but if your like me i don't care about saving fuel. I have a 1981 Ford granada with a 351W (NOT STOCK) with a C6 trans Pushing over 400HP and it is an **** of a ride. I hope this info helps if you have any other question please ask sent me an email at [email protected].
BroncoJoe19
I do believe the question was what is the best way to fix this problem. I would personally just buy it and drive it. If and when he falls in love with it then worry about restoring it.
I guess I stayed focused on his original question which was...
"hes asking 2000 but in a round about way told me he'd take 1500
is it worth it?"
When I asked how much would the body work repair cost?
The cost of the body work, according to JSM is approx $1000 whcih brings the cost of the truck to $2500 or $3000.
yo!
For historical (or hysterical, because Many Bronco parts are going, going, gone) puproses;
Roof Cracks Repair Kit pic in TSB 96-20-11 for 80-96 - part# F5TZ-9850223
Source: by Ford via Trucky18
Article No. 96-20-11
SHEET METAL-ROOF CRACKS-REPAIR PROCEDURE
LIGHT TRUCK: 1980-96 BRONCO
This TSB is being republished in its entirety to include Bronco through the current model year of 1996.
ISSUE: Cracks may appear on the roof panel or on the corner panel sheet metal near the end of the drip rail at the Bpillar.
ACTION: Repair roof sheet metal cracks by using the Roof Repair Kit (F5TZ-9850223-A). Refer to Instruction Sheet
#6661, included in the kit, for service details.
NOTE: BE SURE TO REPAIR BOTH SIDES AT THE SAME TIME. IF ONLY ONE SIDE IS CRACKED, ALSO REPAIR
THE SIDE THAT IS NOT CRACKED.
The Roof Repair Kit (F5TZ-9850223-A) contains the following:
dhpt99
florida
Tailgate isnt a big deal and 130 some 1000 miles isnt to bad mines got 155000 and still runs great (knock on wood [dont wana jinx it]) To me it sounds like a good deal.
