help a brotha out
95 buckin bronco
tennessee
ok so im tryin to change my ball joints on my 95 bronco and i cant figure out how to get the spindle off.i have the abs sensor dust cover off i have the studs out and i have the dust shield for the brakes unbolted.i dont know if the spindle is being held in with a retaining clip or what but it will not budge.also i have never done ball joints before so if anyone can tell me how those are suppose to come out it would be greatly appreciated.i know the upper comes out first but the book says u have to take out the retaining clip but the ball joint is up in its houseing and i can not feel the clip so i dont know if you have to drill it out or what but i know whatever i was doing wasnt right so any help would be nice.thanks!
monch915
El Paso, Tx
I have never actually done the work myself but my ball joints are also in need of replacing. I asked a couple of mechanics and they told me it requires droping the axle in order to replace them. That's why I haven't had it done yet. Because It's kinda expensive due to labor costs.
yo;
Look @ this; Installation in a 95 (axles removed only for gear replacement)
Source: by Ian L (stangmata, stangmata50l, Bronco) at http://forums.bucknakedoffroad.com/index.php?topic=119.0
Ian did a nice job!
Especially;
Step 6: Spindle Removal
Remove the spindle nuts using a 1/2" drive 17mm socket and a breaker bar.
Once nuts are removed, it may be possible to knock the spindle loose with a block of wood and a hammer. I however, had to get a spindle puller.
Spindle puller AutoZone p/n 27104
Slide Hammer AutoZone p/n 27033
They ran me $45 for both pieces.
It simply screws on to the spindle. Very easy and quick to use.
Here is what you will be looking at once the spindle is removed
read more...
Cn you rent these tools locally?
95 buckin bronco
95 buckin bronco
tennessee
thanks buddy that was alot of help but there is one thing that i just cant understand the upper ball joint how does it come out i just cant get it i know once it comes out the rest will just fall into place.thanks again!
yw,
Clip?
Maybe a prev owner used a snap ring that often comes with a replacement ball joint? I is prob rusted into place;
As Ian wrote; he broke a breaker bar!
Removal Tips Info & pics
Source: by Zach K (BurnedB, BurnedBronco, Badassbronco) at http://www.supermotors.net/clubs/superford/vehicles/registry/1549/28053
it more or less shocks them loose
