BroncoJoe19
So even if your coolant is topped off, you have luke warm air at best.
THere are three other possibilities.
1. The heater core is clogged and needs to be replaced. If it is leaking it needs to be replaced. It is located on the passenger side up behind and perhaps a llittle below the glove box. Ifit is, and has been leaking onto your carpet, you should see traces of it there.
If your heater is clogged, you could try disconencting the heater hoses and forcing water through them with your garden hose. It *may* flush enough gunk out of it that you *may* get accaptable heat. Past experience with other cars, is that although that will *help* it won't be nearly as satisfactory as actually changeing the core.
2. It is possible that the outside of your core is blocekd with leaves and crap. Please see the other thread I pointed regarding that.
3. There is a temperature "blend door" that is actuated by either a cable mecahnism, or a vacuum mechanisim. The door directs the air from the blower to travel into the cab either through the heater core, or around the heater core. IF that is not moving by way of the cable or by way of the vacuum actuator, AND/ OR if it is not fully sealing and is allowing air to go around the core when it is supposed to be going through the core then you will not get much heat.
joe
joe
