One possibility that has been confirmed by other Bronco owners in past few years after I posted this;
Headlight Switch Fires, Part Number SW-2103: "...Over the past two years, this office has experienced fires caused by another potential problem in Ford vehicles. The problem exists within the dimmer portion of the headlight switch in Ford vehicles. The light switch involved is a Model SW-2103. These are the pull out type headlight switches usually located in the lower left corner of the front dash of Ford vehicles. The headlight portion of the switch has two pullout positions, the first for parking lights only, and fully out for headlights and parking lights. The shaft of this pull-out light switch can be turned clockwise and counterclockwise which activates a dimmer switch, lowering and raising the intensity of the lighting in the instrument panels respectively. Fully rotating the shaft counterclockwise past a notch activates the interior lights within the vehicles.
The potential problem exists within the dimmer portion of this switch. The dimmer mechanism consists of a metallic resistive coil set inside a ceramic disc positioned over the shaft of the switch. The coil is exposed on its front side away from the passenger compartment. The front side of the coil passes across a contact permitting a current to flow through a certain portion of the coil when the switch is pulled our in its first or second positions. The greater amount of coil through which the current is permitted to pass (clockwise most position) creates the greatest resistance and therefore dims the dash lighting to its lowest intensity. The opposite position provides greatest intensity. Through our investigations, we have found that the coil can fail owing to wear and/or possible material defects or damage. A fractured coil can maneuver itself free of the ceramic disc permitting it to come in contact with the metal bracket which mounts
and grounds the switch to the vehicle.
MIESK5 Note; This could cause a high current drain that causes lower batty voltage thereby the fuel pump relay coil does not sufficient power to close contacts to feed voltage to Pump. Turning off Head Lights gives more voltage back to relay coil thus closing contacts and providing power to pump.
low or no power reaching the fuel pump. Start testing at the fuel pump relay. The relay must respond to the EEC and the relay contacts must be a low resistance path for fuel pump power.
check relay Voltage at pump power terminal; must be within .5v of battery power
Check battery voltage w/head lights ON w/engine off.
do same eng on and then watch voltage when HD Lights are turned on.
This is by a good friend here that goes by another handle...
Testing, Ford (Bosch Type); "...Fuel pump relay switches, and other relays are similar to the starter solinoid, in that they make a high amperage connection through a switched low amperage connection. There are two smaller connections, and two larger connections. TO test it, apply 12v to one of the smaller connections, and ground the other smaller connection. (I used to small aligator clipped jumper wries separated by a small piece of cardboard to keep them from shorting against each other.) You should hear it click. Then check for continuity between the two larger connections.Now remove the power from the smaller connections and recheck continuity between the larger connections.With power, one should have continuity, without power it should be an open circuit (no continuity)..."
Source: by Poppy at
http://www.fordforumsonline.com/forum/electrical-lighting/144-howto-check-relay.html
When this occurs, a current can flow through a portion of the coil creating high temperatures melting the metal material of the coil and possibly igniting surrounding combustibles. This mechanism has been observed in three separate incidents by this office. Two of these resulted in a fire. The mechanism is precipitated by wear and/or defect in the coil mechanism. If the former is true, we expect there will be an increase in fires caused through this mechanism given an increase in service time. To this date the problem appears to be somewhat limited. However, this particular light switch has been utilized in numerous Ford vehicles. Therefore, a small increase in failure rate owing to age and wear could result in a significant increase in fire losses. The SW-2103 Light Switch Assembly discussed above is reportedly installed in the following Ford vehicles: 1986 -1997 F100, F150, F300; 1990-1994 Explorer; 1987-1994 Ranger; 1987-1990 Bronco II; 1992-1997 Aerostar..." Source: by
http://waltersforensic.com/articles/fire_investigation/vol6-no3.htm
Miesk5 NOTE: a
shop or PO could have installed this PN in other model year Broncos, see the Ford info below in the Buyer's Guide Results by FORD: Part Number: SW2103 Description: Headlight Switch, Manufacturer: Motorcraft. Years: 1990-1994 Applications: 535: 1992-1994 Bronco; 1990 Bronco II; 1990 E-150 Econoline; 1990 E-250; 1990 E-350; 1990 ******; 1991-1994 Explorer; 1992-1994 F Super Duty; 1992-1994 F-150; 1992-1994 F-250; 1992-1994 F-350; 1990-1994 F53; 1990-1994 F59; 1990-1994 Ranger
Another issue could be the grounds at passenger side fender apron next to battery
Fuel pump relay or battery power feed was open (wiggle power connections while running and check for stall)
