You can use all those parts on your carbed block but if its a roller motor then you must install the roller lifters this can be done easily if you have a donor motor or I think its crane that sells a retrofit kit with the roller lifters ,alignment bars, and the spider that holds them in place you will have to drill 2 holes in your block for the spider hold downs , And then the cam being steel you will need the steel gear to go on the distributor and if your making it fuel injected you will need the TFI distributor ( I have one Ill sell ) Then youll need the EEC harness , computer , all sensors , And the throttle body . And last but not least the oil pump drive shaft is a weird length in the roller motors that being because the distributor shaft is longer so they made the shaft shorter so that will have to be changed . Hope that helps
/emoticons/
[email protected] 2x" width="20" height="20" />
