front sway bar extended links
fordsohc46
fordsohc46
searcy, arkansas
i have a 95 bronco that was lifted 4 in when i got it i noticed the front sway bar was missing. i got a new bar and hardware from the junkyard but the links wont bolt up bc the fram is higher than stock. has anyone had this problem with their lifted trks and do you know where to extended sway bar links?
Most people remove the anti-sway bars since hey limit suspension flex when offroad. Some of the lift kits provide a pair of drop brackets to lower the mounting of the stock front sway bar. these brackets are merely 2" square tubing that bolts between the frame and sway bar up front.
