Front end torque specs
96bluebeast
Anybody have torque specs for front end? I'm going to be replacing ball joints, u joints and spindle bearings. Need torque specs on hub, caliper and bj's and any others I'm not thinking of
If I RECALL, it is for a 96 Bronco..
If so,
96 Bronco-F-Series Workshop Manual (PARTIAL) by FORD via http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
Section 04-01B: Suspension, Front, 4-Wheel
Torque Specifications, F-150, F-250 4x4 And Bronco
http://www.diesel-dave.com/vehic/manual/stj/stj41b28.htm
Section 04-02: Suspension, Rear
http://www.diesel-dave.com/vehic/manual/stj/stj42017.htm
Section 05-03A: Axle, Front Drive, Dana Models 44 and 50
SPECIFICATIONS
http://www.diesel-dave.com/vehic/manual/stj/stj53a22.htm
Includes:
Top Ball Joint Stud Nut 100 ft lb. —
Bottom Ball Joint Stud Nut 91-110 ft lb.
Spindle to Steering Knuckle Nuts (Both Sides) (Model 44 35 ft lb
I have to roll now.. take time to go through the other sections such as...
REMOVAL AND INSTALLATION
Spindle, RH and LH Shaft and Joint Assembly
http://www.diesel-dave.com/vehic/manual/stj/stj53a08.htm
Section 06-03: Brakes, Front Disc
SPECIFICATIONS
http://www.diesel-dave.com/vehic/manual/stj/stj63019.htm
tsebalj
