Front clip swap from 1990 to the 1992
sgtpowell88
can anyone tell me how to change the wiring in my 1990 bronco to how the 1992 is wired when i do the swap because under the hood of my 90 is a bunch of relays with the fuse box being under the steering wheel and on this 92 from clip the fuse box is under the hood instead of all the relays
Last I checked, you don't need to re-wire anything when changing the front clip. The only thing that must be changed are the connecters for the lights.
S
sgtpowell88
ok so i can just leave it as relays and take that fuse box out of the 92 from clip?
Is their a problem with your current fuse box that you need to replace it? If all your doing is swapping in front clip you don't have to change wiring or the location of anything.
Are you swapping engine parts into the 1990 Bronco from the Donor vehicle also?
Coastersfwb
