Front Axle Pops
4xfan78
Georgia, augusta
I would check the hub first. If thats not it I would lift the front end off the ground with it in 4 wheel drive and turn the tires by hand and see if you can pin point the source of the noise.
STLKIKN
Calgary Alberta
Is this a new noise?
Does it make the noise all the time?
On dirt?
On pavement?
Cornering?
Straight line?
walterm
walterm
Baton Rouge, La.
we checked the hubs, put new ones. got the rear off the ground put it in gear, rear tires turned, front drive shaft turned but not the wheels. I think its in the third member. poss. broken spider gear. oh, and everything in the front axle is still stock
larrypilkey
