First Ford - '78 Bronco
sidehiller
I just bought a '78 Bronco and I know nothing about Fords. I've had Chevys since I started driving 30 years ago.
Anyway, the Bronco has no dents at all, original blue paint, a little rust on the floorboards. It needs tires, shocks and a heater core.
125,000 original miles, 60,000 on engine (Old guy who owned it said it has a 390, but I'm not sure) it runs strong, no leaks or smoke.
4 speed tranny, 9" rear end, Dana 44 front. It will smoke all 4 in 2nd, 4hi. Running boards have to go away of course.
I am thinking of a 2" to 3" lift with 30" Swampers to start with, maybe a set of lockers. I will just use it for fishing & hunting and pulling my snowmobile trailer.
I paid $1500 for it. Did I do OK or was that too much? I will post pics later. Oh yeah - it also has a nice dual exaust.
BroncoJeff
fLoWmAsTeRs=RuMbLe
Polk City, Florida
I just bought a '78 Bronco and I know nothing about Fords. I've had Chevys since I started driving 30 years ago. Anyway, the Bronco has no dents at all, original blue paint, a little rust on the floorboards. It needs tires, shocks and a heater core.
WELCOME TO THE ZONE...!!! IF YOU HAVE ANY QUESTIONS SOMEONE ON HERE CAN ANSWER THEM :D /emoticons/[email protected] 2x" width="20" height="20" />
Welcome to Bronco Zone!!! Looks like the Bronco is in decent shape as far as the body, and hasn't been lifted or abused. The 78 came stock with the 351M or 400m V8, but it's possible that the prev owner put in a 390 FE V8. If you can post a pic or two of the engine, someone here may be able to tell you what you have. Key points are the timing cover and water inlet location on top of the motor. These old Bronco's are a blast to drive and work on, I picked up a 78 last year. Good luck, JSM84
Welcome to the Zone > . You betcha you did all right. That should clean up to be a real beauty.
muddinlate86
va.beach
well i know your used to chevys so ill let you in on a secret.you dont need a lift to run 30's!only chevy crap you got to lift to fit bigger tires.o great deal btw
dirtrider883
Spring Creek, NV
First i would like to say welcome to the zone. Second you got a good deal I paid 2500 for my 78. Third you should b able to fit 31s under it without a lift. I have 4"s of lift and I can get 35s under it but they rub, so I rn\un 33s.
