Engine Swap
mudmonster
Pennsylvania
I have decided to put a 460 in my 79 Bronco. I need ideas as to performance boosters. The Bronco is mostly stock, if that helps at all.
FourXFord
28023[/snapback]
Two years ago I dropped the timing chain in the 351M (with 200K miles) so it was replace or repair time. I went with a 460cid engine from a 78 lincoln, and used the kit from L&L Products to install it, I also sprung for the Ultra flow headers (in-frame) and then fabricated my own brackets for alt, power steering. Only problems encountered were a defective oil pump, and increased tire wear:p
Mine is a 78 bronco with 33x12.50 tires, 3.50 gears and was a DD till $3.00/gal gas!
If your's is equiped with the stock C6 trans, it is a good idea to have it rebuilt, or freshened up a bit during the swap as mine lasted about 2 months with added tourque and horsepower.
Ravin351
Connecticut
28023[/snapback]
Does the 460 bolt up to the same C6 the 351M linked up to when stock?
M
mudmonster
Pennsylvania
I don't know if bolting it up to the C6 in the Bronco would be a good idea, though. The tranny is almost completely beat. Doubt it has very many miles left.
Ziggy
Riverside, Ca
Rebuild the tranny while you have it out. Either do it youself for around $400.00 or have it done professionaly for around $1000.00. Haynes has a real good book on rebuilding the C-6 that will take you through it step-by-step. If you have it rebuilt by a good shop, ask them about up-grading it with AO4D guts to drop your 1st and 2nd gears.
figjeti
