engine swap
Johnny Reb
West Virginia
Will a 351 C use the same engine frame mounts as a 360, if not, what mounts will. Will mounts for a 302 do?
Yes. With the 360 MOTOR MOUNTS ON THE MOTOR--lower the motor down in place and you can mark the location to where you will have to drill the new holes in place. Now,if you use the stock exhaust manifold--you will also have to notch the backside (driver side) of the MOUNT FRAME. If it is a 4 speed transmission.You will need to use the 352-360-390-428 hogs head. (bellhouseing) You will also have to re-align the clutch support on the frame.
fred tyler
