Hi, everyone. It has been a while, i have been really busy lately but now i have a problem. My wiring harness is dying quickly. About 2 weeks ago, i took about a 2 hour round trip in my bronco. on the way back with only bout 15 minutes i stopped at a store. when i returned the vehicle wouldnt start. after some quick troubleshooting, i assumed that the problem was the solenoid and skipped the connection with jumper cables and the truck started right up. i drove straight to napa and picked up a new solenoid only to figure out that it wasnt the solenoid. i started testing the voltage and found that there was no voltage coming from the small activation wire when the key was in the start position. i replaced the end to no avail. i then replaced the switch that controls all of the key functions. this is located under the dash near the steering column and the different positions are activated by a linkage that runs from the key to the switch. this also didnt give any results. all of the accesory positons still worked. i went to wal-mart and got a push button starter and installed it, connecting it to a ignition-on 12v source in the fuse box. and ran a new wire to the starter solenoid. the truck starts fine now. two days later, both backup lights went out simltaneouly. now today, my blinkers stopped working but the emergency flashers still do. my question is, has the wiring in the harness stopped working like this for anyone else. could i have a short somewhere, and also i think i heard that f-150/broncos were prone to this kind of failure and possibly fire caused by this and the was a recall issued but i can find any informaiton on this. Does this recall exist or does anyone have any suggestions on fixing these problems? thanks
