i just purchased a 1982 bronco with 351 and dreaded eec iii. the carb has already been swapped off the variable venturi style, but it still has the non adjustable distributor. I noticed the engine is very weak and traced the vacuum lines and discovered the map sensor has been removed and lines plugged----so no vac advance! thinking of just dropping in an hei. Any thoughts or suggestions? this will not be a daily driver, just an offroad vehicle that will occasonally pull trailers, etc----so torque is most important. thanks
