custom_78
My bronco didn't sit level and already had a 4 inch lift kit on it, but I wanted it to sit level. I bought some aluminum round stock and cut it down to the size that I wanted the lift to be. After it was cut I made sure it was truly flat by using a lathe, but you could also use a sander. After it is true and flat use the bottom spring cup to mark the two holes that have to be drilled. Clamp the spacer blocks into a drill vise and use a drill press to drill them. Make sure the drill bit is long enough to drill through the entire spacer. When your done get bolts that are how much ever longer your lift is taller. I made spacers for the front of my bronco that were 2.5 inches tall to give me a total of 6.5 inches of lift.
