drivetrain questions
texan79&96
in using a 203/205 doubler i have a 203 on the bronco now but the 205 is from a 79 pickup. what do i need to do to use the bronco type driveshaft?? also if i can get a 76-77 pickup with 460/4spd/203 wont it be pretty much measure/drill brackets and bolt in besides the different brake setups to get the tranny/t case combo in? is the spacer from the tranny to tcase longer than a bronco? if so does such a part exsist?would an earlier powerbooster be the same as a 78? i plan to use f350 booster but are different styles in 78/79 so i need to know to get a 78 or 79 type. it never ends......but thanks alot.
fred tyler
