Dizzy
MDDYATV
Fallon, Nevada
so I bought an 84 351w 2bbl bronco from california and now I am trying to lets just say make it run better. I have taken off all the smog pump stuff and still trying to figure out all the useless vacuum lines but my question is on the dizzy did they make a special dizzy for california?
BLADE262US
Michigan
Alot of the stuff on the california vehicles is special especailly the emissions system . I think the mass air systems were used there first as well . That dizzy is special kinda looks like a TFI but not quite a normal one and surely not the duraspark unit you would normally find an an 84 . Does it have a servo on the carb ? throttle position sensor ? If so look behind the kick panel on the drivers side there should be an EEC module there post the numbers that are on it . :D /emoticons/[email protected] 2x" width="20" height="20" />
M
MDDYATV
Fallon, Nevada
this is the picture of the right side of the carb. I am considering going to a holly 500CFM 2bbl will I also need a new dizzy?
attachment=4380:bronco_018.jpg][
M
MDDYATV
Fallon, Nevada
Ok so this morning while the bronco was warming up. I took off the kick panel there is a cover that is there being held by four bolts. i didnt have any wrenches with me so I will check when I get home. I hope the pic of the carb will help I dont know if it has the servo on it.
BLADE262US
Michigan
Looks te be a very early EEC emissions control system . Really need the numbers to find out for sure . You will probably have to remove it all and go to a standard ignition to get away from that setup :D /emoticons/[email protected] 2x" width="20" height="20" />
Coastersfwb
