replacing the rear u-joint is a farly easy job right?i ask because i saw notice of having a shop rebuild the driveshaft....just from looking at it i think i can replace the u-joint without even completely removing the driveshaft...am i in over my head?
yes it is very easy. you will need to remove the whole driveshaft and put in on your workbench or in a vise. the rear is acually the easier of the 3.
all you need is a c clamp, peice of pipe, screwdriver or needlenose pliers, and a 3/4 inch crappy socket, a hammer and a vise.
easiest route to go:
pop off all the g-clips
put the c-clamp on one of the caps and crank down on it by using the piece of pipe as a breaker bar to turn the c-clamp using the socket to pop them out
you can also do this in a vise if you do not have a c-clamp
repeat for all 4. (if it does not work go to autozone and rent a ball-joint puller set and hit it with the impact and they will come right out)
good luck!
the c-clamp worked on my 1990, but i had to rent the puller on my dads 2002 pickup! lol rusted (its a gmc)
/emoticons/
[email protected] 2x" width="20" height="20" />
