dash board
bronco venezuela
hello everybody,
I have a bronco 300, 1991 4x2. I would like to know if a 1992 or newer dash board will fit, or if I have to adapt it. The reason of this change, my old dash board is toasted by the sun, thanks for your help.
yo!
WELCOME!
No, it won't operate at all using any Ford 92-96 and up cluster or speedometer (called the Programmable Speedometer Odometer Module (PSOM) in 92-96 Bronco, & Ford trucks and other year Ford cars)
I know of only one person that did make major changes to his early 80's Bronco and then swapped in a 92-96 instrument cluster w/the PSOM; he changed the 9" rear differential to a 92-96 8.8 w/Vehicle Speed Sensor (VSS) & Internal Tone Ring (also called Exciter Ring); Source & pic; Item #32392; "...This is the ring inside the axle housing that the VSS/abs sensor reads off of. 8.5" outside diameter,108 Teeth..." http://broncograveyard.com/images/catalog/zoom/88EXCTRTONERING.JPG
Source: by OUR SPONSOR HERE, Jeff's Bronco Graveyard
fyi, Sensor, VSS or RABS?; by Bronco1 - "Depending on the year; 1992 + - It's called a RABS sensor, or a DSS (diff speed sensor), or rear axle sensor; others called it the VSS
and swapped in a 95 4.9L from F-150, complete w/ computer, all accessories, and a 96 Bronco gas tank & electric in-tank fuel pump.
The 92-96 PSOM and cluster needs the Vehicle Speed Sensor (VSS) mounted on the 8.8 rear diff w/tony ring as well as the harness.
there are 2 ways to wire it; the hard way as he did by installing the 4WABS system and running the VSS signal (2 wires) thru the 4WABS Module and onto the PSOM; or using the F series wiring to run from VSS to the PSOM.
I have to look @ all the other gauges and indicator light in the cluster to see what has to be done to make them work.
Here is the 96's overview diagram;
Are you talking about the dash part that has instruments mounted on it, or are you talking about the dash cover on the top? If the top is what you are asking about, then any dash cap from an 87 - 92 should work. However, 93 - 96 is a different design.
eholt80
