here ya go your grass hoppa. before you ask, no i dont drive it everyday, but that has nothing to do with the suspension. if i had 1/2 ton springs all the way around and not a 1/2 ton front, 3/4 rear, it wouldnt ride so much like a tank. but gone forever is the vague, slightly floaty feeling of the TTB. it now rides very squarely and confident on the road. it does ride a bit rougher on bumpy sections, but that is going to happen since the tires are no longer independent of themselves. what i am NOT missing, however, is the ****** alignment and utter lack of articulation suffered by the TTB. i can lift it as tall as i want, and all i have to change are springs, trac bar length ( no prob since mine is adjustable, and C-bushings.) much easier than TTB lifts. and it all can be accomplished in half the time. i'll give you some highllights of my swap. and i didnt need to trim my xmember, but since the extended arms give me more flex, i didnt see why it would hurt.
new suspension consists of superlift 78/79 9" lift springs, radius arm extensions from Bent & Twisted Enterprises, and a superlift adjustable track bar.
this shows how much longer the extensions make the arms. and before you ask how it helps, think of some simple geometry
driverside bucket bolted up. in retrospect, i should have pushed it forward to the slot just aft of the steering box
this is a view of ride height with 9" springs. for an idea of how it would look with 6" springs, visually subtract 3" from the top of the housing to the bottom lip of the xmember
radius arm location
another view of ride height
as it sits
track bar bracket. consists of 1/4"x1/4"x2" square tube, 3/16" plate gussets, and .120 wall DOM brace welded to xmember. it aint budgin'
'nother view
looking at the tire
and how does it perform?
