I picked up an electric w/s wiper assy to switch out my vac ones. I was under the impression the electric would just slip into place. Not quite. Obviously, the distance for the wiper shafts are closer for the electric linkage. I found a drawing in Auto Krafters catalog, which hopefully shows the linkage in the stopped position. Eyeballing the assembly in mine, I guess I could 1) Drill 2 new holes the correct distance apart. 2) Drill out the driver's side, where it is, to accept the new wiper shaft & drill a completely new hole the correct distance on the passenger's side. 3) Cut the main linkage rod & splice in a piece of metal to extand it to the correct length & mount the wiper shafts thru the existing holes after drilling them out to fit, of course. Any advice or suggestions, I'm wide open! Thanks!
