Catalytic Converters
mitchellt
Need to replace my exhaust system. On my 90 Bronco I have 2 cats. Was wondering if I could only remove the rear and go with a 3" muffler and tail pipe. Or just scrape the whole system and go with a single cat system.
Captain D
New Orleans
If exhaust is good from engine to first cat,go with 3" back. Worked for me.
The 2 cat system is the same as the more modern single cat which has two functions inside. Notice where the air injection port is, between the two. Check out a universal replacement, the port is in the center of the cat. If you need to replace one then the other will probably be going soon. I'd get new pipes and a universal cat. You can get Walker pipes from the exhaust manifold back. Not inexpensive, but if you do it right you won't be doing it over again next year.
eholt80
