when i upgraded to an edelbrock performer intake and 4bbl, i also had to buy an adapter kit from them, to fit the 'special' ford transmission kickdown lever, just look up the carb manual online and you should be able to find part numbers. you may need to add your own custom extension on the lever, i just bolted on a thin aluminum piece bout 4in long. and ive heard others have the same problem with similar upgrades.
as for the size of your carb, 600cfm is plenty for a stock motor, even with the performer intake. if you plan on building the engine up to race or for fun, you could go up to a 750. but simply bolting a bigger carb to a stock engine is just ****** in the wind, unless your gonna start replacing the timing set, camshaft, heads or at least a pair of headers.
