bronco engine
Fritz180
Fairfield, New Jersey
you might want to make sure it is not a 351m in it already, because from what I've read it is pretty pointless and hard to do, to put a 302 in a 78 or 79 bronco. I would look at the numbers on the block before you proceed to do anything.
ropemansavage
UTAH
The 302 is the same block as the 351 windsor make sure that you have the right 351 before you start your project.
All the work required would be the same as putting in a 460. In my opinion you would be way farther ahead with the 460.
Sandoval_broncosauria
