Brake pedal not rebounding
T
Trecar
Guest
93 5.8 xlt 73000 original miles.
What I have done:
Bled nasty black fluid on all 4 corners.
Did my best with a propane torch to check for vacume leaks. My hearing isn't what it used to be...
Replaced booster.
Replaced master cylinder.
Still no pedal rebound....At a complete loss. Any help would be greatly appreciated!!!
T
Trecar
Guest
Nevermind.
Save yourself some work & money. Check the pivot shaft/bushing on the pedal assembly. Rust is the enemy!
Yo Trecar,
Welcome and THANKS for coming back with your solution!
Find out if speed control, if equipped, recall work completed by a dealership. Call local dealer or register and view status @ https://owner.ford.com; or @ https://vinrcl.safercar.gov/vin/ ... have VIN ready.The affected vehicles were previously repaired using a wiring harness that is not compatible with the vehicle circuit polarity. As a result, the fuse is located in the output circuit rather than in the intended input power feed circuit, and may not offer the intended protection in the event of an electrical short to ground. This could result in an underhood fire. Dealers will install a new wiring harness, or replace the mating electrical component. east302 provided following for his 93 "I found the recall information on alldata...didn't know it was even there so that's a plus. Mine has the updated harness with two fuses instead of one, so it looks like the recall was addressed correctly."Use this guide by jowens1126 @ https://www.fullsizebronco.com/forum...ml#post6530073Note that the 93 recall is different that the other years.
Here is the 1993 Bronco Dealer Brochure in Google Drive @ https://drive.google.com/file/d/0B-x...NNcGprQTA/view1993 Bronco Dealer Training Video via silver70 @ https://m.youtube.com/watch?feature=...&v=Fvne3bosE3s1993 Bronco, Venezuela Commercial @
Free registration for some wiring diagrams (86 through 96) and Technical Service Bulletins, (80 through 96), same as by Ford @ BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
stevedave
