Brake Lines
Ranger187
I was looking at this kit: http://broncograveyard.com/products/cat/20...SS/?o=&st=brake
Seems to be the one that matches up to my lines, but the question is, will it work on an 86 BKO? I just replaced the calipers and pads and noticed the rubber hoses going to the calipers are shot and cracked, so while trying to replace them, I had no such luck. These are the ogirinal lines and I can't remove them, so I was just going to remove all the front lines, cut the ones I couldn't get off, and dremel/drill out whatever is left and then slap some new ones in. I'm not fond of making new ones. So does anyone know where I can get the metal lines premade or can I use the above kit on my front?
I don't know if these specs are needed but supplying anyways.
4.9L
C6
Carb'd
david@holycitytransportat
