body vs. suspension lift
kturner
Kennedale, Texas
will a 3" body lift allow the you to run the same size tire as a 3" suspension lift?
i bought a '95 bronco that the pervious owner said had a 4" body lift (probably a 3") i just want to know what my options are for running bigger tires.
Justbust1n
walkertown
i got a three inch life and a 6 inch suspention before i put my 6 inch suspention lift on i had 33 inch tire with out any rub. i think you might could get away with some 35 inches with a three inch body lift .overall i think body or suspention will give you the overall same results but a body lift is alot cheaper but you will need to get extended brake lines if your gonna really flex it out because it is really uses all of the line when you lift the body up like that
89Bronco58
Jersey
either way its 3 inches of lift, so its gonna be about the same, id personally go suspension and you can clear 33's without any lift on a bronco so with a 3 inch lift you will clear 35's fine
Coastersfwb
