Body Swap
project 86
Has any one got some advice on swaping the body of my bb2 on to a f/s bronco fram. I'M looking for any kind of info, advice and helpful hints.
P
project 86
not sure how to take your queistion. but i'll try to give answer, i'm up grading to a 5.0/eo4/stk. transfer. everyone i have talked to around home says my d28's won't hold up. so i thout it might be easer to change bodys instead of axles.
andre
gatineau hill quebec
frame off restoration or what frame can you fit it on ???
frame off restoration depend's how are yopu going to use truck dayly driver or week- end driover or mud bug ??
there many way to set up truck need to know
chillsam
Im doin the same thing but with 91 swb ranger bod on 91 fs bronco chassis 300 6 e4od every thing up to strength 4 the chassis stand point n "I" think putn the lit wieght ranger sheet metal on it makes sense i say do it DARE 2 B DIFFERNT"
andre
bronco frame are strait as for
ranger are not so you/re have lot of work to fit front fender clips
bacause it has a box on ranger frame going upward at rear of cab
you can put a cab of ranger on bronco 2 frame need to mouve frame mouting
as for upgrade broco 2 can use explore 91 to 94 parts like tranm trany engine ecm and wire
that way emission test will pass if there one where you live
on bronco 65 to 74 the frame can be fitted on bronco 2 body but lots of mod to do has for as body to frame fit
and some wire work too
done my share of swap and still got more to do
by the way any one that as 1989 90 bronco 2 use the fr grill of explorer 90 to 94 look lot bigger then it is
Gary wilder
