Best way to replace valve covers
michael1989
California
I need to replace both valve covers on my 89 5.0L EFI. I was wanting to know the best way to do that.
Bronc76
What is wrong with the covers that they need to be replaced? Or are you talking about the gaskets?
As far as I know, there is no "easy way" :-& Unfortunately, with an EFI engine, you will have to remove the intake manifold to get at it. However, this is a good time to clean the intake manifold, I'm told it does wonders for the engine operation :) /emoticons/[email protected] 2x" width="20" height="20" /> .
michael1989
michael1989
California
I heard that you take the radiator out so you can sit there and work from there. What do you think about that?
Krafty
Ontario Canada
its a waste of time taking out the rad just to do the valve cover gaskets, there is enough work to do without draining and removing the rad. but if you want to im not gonna stop ya
Ditto Krafty's post. Just get yourself a 2 ft. step ladder and work off it, or a one of those 1-1/2 ft painting platforms (probably get one from Lowes or Homer Depot). I keep a 2ft stepladder in the back of my truck for working in the engine compartment.
Krafty
Ontario Canada
im tall enough that I could get away with using a spare tire when working on the bronco, cause you should always have one of those around, ( when a tire blows out in the middle of a trail 3 hours away from home and you don't have a spare. Be glad old jeeps have 5x5.5)
Bronco Kid!
Silverdale Washington
yeah hey no real need to take radiator out but if you want to then its a good excuse to change your coolant, also its really a pain to do but you can pull the plenum off the intake and then you can get right down at your valve covers
1987BroncoProject
Georgia
I posted the same question about a month a go and Beast Runner gave me a step by step instructions including detailed pictures to get this done. It is pretty time consuming but not overly difficult to complete. I would say that you should scroll down in this forum about page 4 where you will see Valve Cover Gasket Replacement posted by my name. Check it out and good luck. It helped me a LOT!!
