Belts...
Matt_V
Have Bronco....need money.
Is my Bronco (82 w/ 351) supposed to have 3 seperate V-belts? I looked in the Chiltons, but couldn't find a routing picture.
it should have 3 v belts if you are running AC
btw, found the Dayco web site awhile ago; it lists their pn's for belts & hoses; w/Effective Length, Outside Circum. Top Width &
Angle
1982 FORD BRONCO - V8 5.8L 351ci GAS CARB N G
Belts / Tensioners / Pulleys
Part Number Description
15285 Alternator to A.P., w/40, 60 Amp Alternator
15300 Alternator to A.P., w/70, 100 Amp Alternator
15375 Alternator, w/70, 100 Amp Alternator
15380 Alternator, w/40, 60 Amp Alternator
17475 Fan & Idler, w/o P.S., w/o A.C.
17525 Fan & P.S., w/A.C. (4WD)
17530 Fan & P.S.
17540 Fan & P.S., w/o A.C. (2WD)
17600 Comp. & Idler
89025 Idler Pulley (Factory Air)
Radiator / Heater Hose
5/8 IN. Heater Hose
70638 Radiator Hose (Lower Curved) 26 3/4 In. Rad.
Cut to Fit
70799 By-Pass
71039 Radiator Hose (Upper Curved) 26 3/4 In. Rad.
71039 Radiator Hose (Upper Curved) 32 1/2 In. Rad.
71040 Radiator Hose (Lower Curved) 32 1/2 In. Rad.
81201 Radiator Hose (Upper Flex) 26 3/4 In. Rad.
81201 Radiator Hose (Upper Flex) 32 1/2 In. Rad.
Click any underlined part number for picture and / or dimensional data
Sounds reasonable to me, I use to have 3, (Crank to alternator, crank to Water pump and PS pump, alternator to Air Pump).
hfrost112
