Ballistic fabrication adjustable cool and shock mounts
Pauliten02
Holtville, CA
Wanted to know if anyone has trying to run them up front on their bronco. Needed extended shock mounts to run fox 2.0 smooth body with resi. Can't find any reviews. Looks like they would work perfect
yo Paul,
Here is one review by Bill; he has written many products reviews and for this product he shows one mod he had to make
http://www.pirate4x4.com/tech/billavista/Ballistic_Shocks/
read their Face book comments and ask Qs; https://www.facebook.com/BallisticFabrication
Some reviews from other Bronco sites;
" have made two orders from Ballistic. Good quality parts. They are a little slow at getting back to you if there is a problem.
Good stuff and I recommend them!" 95 BRONC0 Procomp/Skyjacker lift rear locker w 4:56
"The coil buckets are from Ballistic Fabrication that i actually bought second hand, but unused, from a Pirate 4x4 member for cheaper. I did weld them onto a piece of angle in hopes to make it a bolt on item, but the hole and the notch out on the driver's side frame rail just did not give me the accessibility on the back side to do so, so i did end up welding them on any way.
They are absolutely great though. I have 4" BDS lift springs (~400lbs/in.) installed currently with the buckets adjusted so that it take the lift out enough to level the truck. The reason why i did this is because i know the Powerstroke is going to make the front squat a little more so i wanted some extra spring to compensate and the adjustability to do so. The powerstroke is an additional 500lbs on top of what's in there now.
New Coil buckets from Ballistic:
http://i59.photobucket.com/albums/g298/keeperman13/Black%20Betty/2012-08-18_20-22-49_988.jpg
" 92 EB, 5.0L, E4OD, D60 HP/10.25"
see many pics @ http://s59.photobucket.com/user/keeperman13/library/Black%20Betty?sort=3&page=1
J’s Bronco
