ball joints, tierod ends
jats
I have a 74 with a 5 1/2" lift I want to put new ball joints in,any idea who has the best moog or ? also going to put heim joint at tierod end any advice on pro or con my bronco wanders figured I would start here. yes it has power sterring
Thanks jats
This is all good stuff...!
However, may not solve your problem.
If, while on jack stands..., you can wiggle the wheel up & down...(while someone watches the knuckle for movement, & it does) Then it's due for ball joints.
The wandering may be the toe-in or improper caster.
S_bolt19
Colorado
Moog are good and so are the "Extreme Series" McQuay-Norris ball joints. You can't go wrong with either. The heim joint steering, who's system are you going to use? I put the Stone Crusher system on mine and some of the wandering went away, but I still have some because of bigger tires.
J
jats
This is all good stuff...! However, may not solve your problem.
I do have 35"s on and I know that is part of the prob. any other ideas;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
J
jats
I think that is part of the prob. I have 35s on mine any other ideas;;;;;;;;;;;;;;;;;;;;;;;;
You've got it covered....
All you can do to these rigs is "caster., toe-in., & a clean tight properly functioning steering system."
A 5.5" lift Req. tuning the front end for proper steering/tracking.
S_bolt19
Colorado
A good steering stabilizer will go a long way in making it feel "tighter". It will dampen the wandering feel, so if your stabilizer shock is over 8-10 years old, replace that and see what happens. That shock gets more work than the 4 on the corners because of all the turning and up/down from the front suspension. But what I would do if you are just looking to clean it up is (and this is in the order I would do it) #1 Ball Joints, both upper & lower on both sides. It's gonna cost you around $200 for the joints alone and probably another $50-60 to have the old ones pressed out & the new ones pressed in. #2 steering stabilizer (the cost of a good shock) #3 heim joint steering (Stone Crusher cost me about $300 + s/h, but is well worth it).
Sandoval_broncosauria
