B-Co Kid
- Joined
- Oct 14, 2010
- Messages
- 235
- Reaction score
- 8
351w/Duraspark II/no EEC/Carb'd--->Hey guys, me again! Im learning now, being a Bronco aficionado is like raising a child, but I digress. So, now..the engine will not start, and by that i mean, the engine does not turn over and the starter does not engage when turning the key. In troubleshooting, I am getting power at the coil and associated wiring, with the key on, all interior and exterior lights and accessories work, and when I use my remote starter (key in run, +terminal of remote starter on the +battery and other lead of the remote starter to the "S" terminal of the solenoid/relay) i hit the button and it cranks up and runs as it should. So, should i assume the problem is in the switch on the steering column, because im all out of ideas. And if it is at the ignition switch, how do I check/remove/replace???
