bidibronco
I have the airbags inside my coil springs on my front end. Anyone know the main reason they're there? I'm assuming they can have air added to them or taken away given the size of load on the front. Anone know what the PSI max and min is on these things. The main reason I ask is my front end is sagging probably an inch (makes for bad leaning of tires and odd wear) and was wondering if I can add air to them and get the front end back to par. I would go get a new set of springs and such but I don't drive my truck often at the moment (gas is rough in that thing) and I'll be putting it up 6" next year and don't see the point in new stock springs at the time. Another thing, when I go anywhere above 35 or 40 my truck has a nasty shake, not the front end shimmy but just a killer shake from all 4 corners, would this most likely be due to unbalanced tires? Well, any help would be great, thanks....
