Aftermarket Guages
89Bronco58
Jersey
ok i got anfermarket water temp and oil psi mechanical guages, i still want my stock guages to work, so i was wondering if anyone knew where i could put my temp and oil pressure fitting into my 302...89 xlt bronco
The oil pressure is easy, put a brass T where the current sender is placed and then attach the sender and connection to the new gauge to it. I got my parts at Home Depot. in the plumbing section. They were WATTS brand part number A-740, A-730, and A-738. I think someone else had to also use a elbow, (A-nnn don't know the number).
As for the temp gauge, you will have to find an unused spot in the water jacket, I had one in the fitting that goes out to the heater. Not sure where you might find one on your intake manafold.
eholt80
