ADJUSTABLE TIE ROD
wileycoyote
Jackson Hole Wyo
WELL I AM IN NEED OF REPLACING TIE RODS. HIT A ROCK LASTWEEK END. THE TIE ROD FROM PITTMAN TO RIGHT TIRE DOES NOT HAVE A ADJUSTMENT IT IS A SOLID PIECE.
MY QUESTION IS THIS, DO THEY MAKE A TIE ROD WITH THE ADJUSTING SLEEVE FOR A 79 BRONCO?
ANY INPUT WOULD BE HIGHLY APPRECIATED. THANX
79highrider
Frenchtown NJ
The piece you are talking about from pitman arm to right side is called the drag link and I don't believe you can get one with an adjusting sleeve. LMC truck carries everything from the left and right side tie rods the tie rod adjusting sleeve, and the drag link, but they are kinda pricy If I were you I would try to pull the whole set up from a donor vehicle (junkyard) as long as the tie rod ends aren't shot. (This is what I did when I hit a stump)
ffxcs08
Super lift makes one and Bronco graveyard sells them...Just put one on my truck. Comes with both ends and sleeve obviously.
