add a leaf
4WHEELIN
i have a 90 xlt bronco if i was to add a leaf would i be able to use bigger tires, is this kinda like getting a lift kit and will i still be able to go off roading????? help
Same answer..;
"Does the job...... just don't try to drink coffee, & never put your tongue between your teeth, while moving.
Kidney belt helps as well." B)
What this means is;
Yes it'll give you a bit of a lift, & a little more tire room.
& sure, you can 4x4 it....
it's just going to be a rough ride ...dirt & street ;) /emoticons/[email protected] 2x" width="20" height="20" />
johnski
You can fit bigger tires without a lift, up to 33's with minor fender trimming. Just adding a leaf will make you sit even higher in the rear than your bronco already does, so it seems kinda pointless if you ask me.
89Bronco58
Jersey
ok i kno this post is a little old but your all busting on add a leafs saying they give a rough ride..well thats bull, bronco's have enough weight in the rear end it does stiffen it up a little bit, but not that much, it will actually feel better to drive it because not only will it have less body roll, but the spring rate will be stronger and offroad you will be able to do more without bottoming as easily
firelt90bronco
Ask me about my job
northeast
If you want the effectss of a lift and the performance that comes with one, get a lift. The add-a-leaf won't give you the same as a lift.
Big Country
San Antonio, TX
i also agree with it being pointless. Just get them repacked and get body lift kit. They are cheap. If you are trying to get bigger tires. I have 33" mud terrains on mine and I din't have to trim anything and the only time it rubsis when i am trying to turn on a dime. Ahhh the short wheel base. I love it!
Coastersfwb
