abs problems
Big Ragu
palm bay fl.
Hi guys, I'm havin ABS problems. As far as I know there is nothing wrong with my brakes. They work just fine. The light on the dash comes on and off when ever it wants. I have all new brake pads and shoes all the way around as well as rotors and drums. Its been to two diff. shops and they are at odds with it . I refuse to go to the dealer cause............well lets face it you see the price of gas as of yet?. I had three people tell me to save alot of money just pull the bulb out and call it a day. this is not looking like a bad idea at this time. any help guys would be great!!!!!!
I did the brakes on a guys truck and then the abs light was on, turned out to be the sensor at on of the front wheels
mbtech2003
cape cod, mass
the bulb is out in my truck too cheep to fix i guess. i think it stops better in the snow now then before with abs but thats just me i guess. with 32's they don't lock up any way uness i really slam on them :wacko:
if it bugs ya and you want to ck it out incl doing a Test;
Diagnosis and Testing
4-wheel ABS testing-1993-96 Bronco models
from Chilton via AZ"]Stop Light Switch
"The anti-lock brake system uses a brake pedal sensor switch which monitors brake pedal travel and sends this information to the anti-lock brake control module through the wire harness. The anti-lock brake pedal sensor switch adjustment is critical to pedal feel during ABS cycling. [/url]"
4WABS System Component Locations, DTCs & Test Connector Diagram
Source: by Steve83
Coastersfwb
