95 Bronco Help with Bad fuel pump?
Bronco Beast 2
by the beach
Have a 1995 Bronco, 5.8 EFI. Wont turn over, can hear continuous humming noise from rear tank area, guessing fuel pump. Where is fuel filter? Any help is appreciated.
WELCOME!
The inline filter is mounted on the driver's side frame rail about midway back
Installation & Diagrams; Scissors Type; BEST PROCESS!; "...Step 1: For the best chance of getting it apart on the first try, start by pushing the coupling together HARD so the fingers of the bail are NOT touching the catch ring on the filter. Step 2: While holding the coupling firmly together, insert the tool (I prefer the regular or low-profile scissor) fully. It may be necessary to rotate the tool so its gap does NOT align with any of the fingers, thus holding them all clear of the catch ring. Step 3: With the tool fully against the catch ring, pull the filter & tool out of the coupling..." Read More; Steve also shows Collar/clamshell tools Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
Do a Self Test for Codes by my pal here, BroncoJoe19
An assistant to write the info is helpful
heat the engine up; idle until temp gauge is in normal range you usually see and when it warms up; shift thru all gears incl Reverse anyway. (leaving this in place in case it starts and runs)
Then turn off all accessories/lights, etc.
Make sure A/C is off and transmission is in Park (automatic)
The engine temperature must be greater than 50°F (10°C) to pass the KOEO Self-Test
and greater than 180°F (82°C) to pass the KOER Self-Test. (leaving this in place in case it starts and runs)
Look Codes up in my broncolinks.com site using the new Search function if in a hurry today.
And Post em here according to
KOEO
& KOER
Coastersfwb
