yo;
For Now;
Check for connector /wiring corrosion
Electronic Pressure Control (EPC) Solenoid:
Description: The Electronic Pressure Control solenoid is a variable force solenoid. The variable-force type solenoid is an electro-hydraulic actuator combining a solenoid and a regulating valve. It supplies electronic pressure control which regulates transmission line pressure and line modulator pressure. This is done by producing resisting forces to the main regulator and the line modulator circuits. These two pressures control clutch application pressures.
Symptoms: Failed on — minimum electronic pressure control pressure (minimum transmission torque capacity). Limit engine torque (partial fuel shut-off, heavy misfire). Flashing transmission control indicator lamp.
Failed off — maximum electronic pressure control pressure, harsh engagements and shifts. May flash transmission control indicator lamp.
Diagnostic Trouble Codes: 624,* 625,* P1746,* P1747.*
CAUTION: The electronic pressure control pressure output from the variable force solenoid is NOT adjustable. Any modification to the electronic pressure control solenoid will affect the transmission warranty. (*Output circuit check, generated only by electrical condition.)
Possible causes
Damaged harness connector.
Damaged EPC solenoid.
Damaged MLP sensor.
Intermittent harness continuity.
Damaged PCM connector pins.
Key off.
Disconnect Powertrain Control Module (PCM). Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary.
Install breakout box, connect PCM.
Connect DVOM to test pins as indicated:
For EPC solenoid:
Connect one test lead to EPC signal pin and the other to EPC VPWR pin. Refer to cover page schematics per application for correct EPC test pin.
For MLP sensor:
Connect one test lead to MLP signal pin and the other test lead to Test Pin 46. Refer to cover page schematics per application for correct MLP test pin.
Key on, engine off.
Observe DVOM display for indication of a fault while performing the following:
Note: In either case, the voltage should remain steady (less than 10.0 volts for the EPC and less than 5.0 volts for the MLP with vehicle in PARK). A changing voltage or one greater than expected is an indication of a fault.
Shake, wiggle and bend the component harness.
Lightly tap on the component connector to simulate a road shock.
