89 Ford Bronco
roadog
I washed it and went to take off and it just quit , it turns over but the fuel pump does not come on . I did pull the relay and hot wired the pump so i know its not that. I replaced the modual on the distributer. I put another computer in it. Checked all fuses and relays. I checked the fuel shut off switch. What the **** else is there?
302 EFI
southerntrax
the fuel pump might have taken a dump. that would be the first place to start looking.
Saint351
Not that this could be it but I remember having a similar problem. I had a cherokee and It was lifted had 33's on it and I let a x-friend drive it. He assured me that he wouldnt break anything on it and wouldnt do anything stupid. WRONG! When I got it back it ran terrible. It just kept rolling over and not wanting to start. It turns out that my x-friend went and took it down our local highlines trail when the puddles were over my hood. It shorted out my throttle position sensor and stuffed mud and water nearly into my intake. Ohh and it burned 2 quarts of oil in the process. After nearly killing my x-friend I had the truck fixed and never let anyone else drive it again. Now this might not be your problem but hopefully you at least got a kick outa the story.
Good luck
Ohh and the throttle position sensor isnt cheap so I would suggest if you have the knowledge about EFI checking it somehow or having a mechanic diagnose the problem would be a good idea before buying the part
Saint351
BRONCO JIM
wisconsin
YOU MIGHT WANT TO CHECK THE FUSEABLE LINKS FOUND NEXT TO YOUR BATTERY.I HAD THE SAME PROBLEM ONCE .CHECK THE THREE yellow WIRES THAT GO INTO ONE THAT RUN TO THE + SIDE OF STARTER SWITCH,THERE ARE THREE LINKS,.THESE WIRES RUN AROUND THE FRONT OF THE GRILL AND END UP CONTROLING YOUR FUEL DELIVERY SYSTEM. HOPE THIS MAY HELP. BJ
Broncoholics
Broncoholics
Washington State
If you washed it the distributor might be wet on the inside. You can dry it out or on the trails just add a spray of WD-40, it works pro. It could be that its not alowing the engine to start or even allow the fuel pump to get power so it doesn't flood out. Newer rigs have these safety components on them.
Just one other possibility. Have you checked the inertia switch? It is there to shut down the EFI fuel pump in case of an accident. It is a small black square shaped thing witha button sticking out of it. press the button in to reset. These have been known to just go bad and drive people nust troubleshooting the problem. If my memory serves me right it is under the dash on the passenger side.
Good luck :-B
M
Mexray
Guest
That inertia switch on an 89 is above the pedals, inside, (on the drivers side, of course). You have to open the drivers door, kinda lay on the mat, and reach up and check to see if the switch has 'popped' to open the circuit - which kills the current to the fuel pump.
BTW...I use this switch to 'theft proof' my Bronco if leaving it by itself for any length of time - parking garage at airport, on the beach in Baja, etc. I just pop the switch up (off), and the fuel pump won't run! Most people wouldn't think of looking at this switch...
Maddog
Just fyi.. Even if you hear you full pump working doesn't mean its pumping.. To find out for sure you have to open a fuel line then put her to work.. Lot of them had diaphrams and they suffer holes.. Washing it and it quiting may just be a fluke.. GL
cawabronco
This happen to me also try the ecc relay. If get got wet it could go out .
Cawabronco
90 bronco
joehelsel2000
i have a 89 ford bronco its a 302 fuel injected well it starts up frist time u start it but u turn it off it wont start back up intell u let it sit ples help me lol
larrypilkey
