89 Fiberglass top
slick351
I have an 86 Bronco Fullsize.
I found an 89 fiberglass top which is flawless. $150.00
? will that top fit my 86?
Thank you
sandmann999
Abandoned Bronco
Moscow, ID
80-96 tops are all interchangeable
33490[/snapback]
If I remember right, the 92 - 96 tops are a little different because they have shoulder belts and a rear tail light. I believe they purposefully made the mounting hardware different so that they wouldn't be interchangable with older ones. But 80 - 91 tops are all the same.
ocalabronco
ocala, Fl
33499[/snapback]
whoopty doo. the outer shape and frame are the same. 90% of cops arent going to know what year broncos had tail lights on the top, and lap belts are easily set up. they will all still bolt up to each other
allman37
