88 bronco fuel tank float ?
hotrodmanIII
do you have to drop the tank?
or is there an access hole beneath the carpet.
and is just float the replaceable?
thanks i got to do this tommorrow , i wanted to know b4 i droped the tank if i didnt have too.
Roadkill
Killeen, TX
Yes, the sending units are replaceable. But, unfortunately, there is no access panel under the carpet. :( /emoticons/[email protected] 2x" width="20" height="20" />
Edit:
Sorry, I mis-understood your original question. The sending units are replaceable as an entire unit, but I don't know if you can get just the float part.
BB33's
Rancho Cucamonga CA
unfourtunately you'll have to drop the tank but it is not very hard and the whole job can be completed in an hour or so
you can cut the floor pan to remove the pump, sender, float;
Fuel Pump Cut-out Measurements for Fuel Pump/Sender Replacement
EDITED URL - http://www.broncolinks.com/index.php?index=1
steve has said that other's measurememnets are not exactly 100% correct; so look closely before cutting
thanks Yardape for heads-up on the bad url!
hotrod; in case you do the cut-out, you can make op an access apnel in the floor pan using whatever or if you want, I know a dude who has cut sections of scrapped Bronco pan that you can use for the panel; they are oersized in re to the cut sections so then can be hinged or bolted in place. or DIY from a yard's B in your area.
Coastersfwb
