87 5.0
machmn
Spfld. M0.
Yes I have a 1987 full size bronco with a 5.0 in it is a roller moto like the Mustangs or not???
And also does anyone know what rearend I have is a 8.8 or (inch or what I need to buy gears and all kinds of stuff for it and just don;t know and also is there any way to make it instead of push button four wheel drive a selector stick in the floor board and hoew costly would it be???Please help I know absolutly nothing about the four wheel drive components and stuff???
KG4OFQ
umong 2 of hte major problems of the 87 they are big and yet small problems. One is the crappy standard locking hubs, the other was some that came with the push button selector for your transfer case.
To go to a manual shifter for the transfer you will most likely need to replace your transfer case, since it is a weak link in the 4x4 system this isnt all bad. Another is replacing the locking hubs from the auto type to standard and it may be as simple as a knuckle out swap. The Rear end I believe on the 87s is the 8.8.
What application will you use the bronco for most of the time. If its a daily driver, and you just want to upgrade to mostly looks enhancments then the rear and 4x4 system wont matter much. Swapping to a 9" means losing your speedo cable unless someone here knows how to mod that problem.
If you are going to do any real offroading then go for the solid axle swap for the front and this along with the new transfer case and chopping a hole in your floor board will get you set. I dont remember doesnt the transfer case still have a manual shifter on teh floor, I saw a friends 86 Bronc with the push button 4x4 and thought he still had the lever, but its also 3am and my brain is nto working.
Just think of your applications you intend to use and plan around it, the 8,8 and push button will do just fine for daily driving and for light to med offroading.
BLADE262US
Michigan
The speed sensor in the rear end is only for the antilock brakes on an 87 the speedometer is still cable driven . Wasnt until 92 with the digital odometer did the speed sensor in the rear end drive the speedometer . :D /emoticons/[email protected] 2x" width="20" height="20" />
M
machmn
Spfld. M0.
Well I haven't been up under it or nothing but I can't find even if the pushbuuton 4x4 worked what do I do just press the buttons on the dash or what they are pushed all the way as far as I can get them to go on I guess my brother in law is were I got it but he said he took the electronic selector motor off and manually put it in 4x4 all the time so I don't know if it in 4x4 or not
M
machmn
Spfld. M0.
and also there is no stick in the cab that I can find
How should it act or drive I know one thing it is squirlier than ****
lefty546
Hastings, MI
machmn.......Where did you find that only little boys wear bowties picture? That's great. Anyway you could email me a copy of that. A couple of my hunting buddies are die hard chevy ****'s and I would like to send a copy to them.
kyleh01
