86 engine help
broncomichael
ok heres the thing about 3 months ago i caught the wiring and vaccum hoses on fire(i know stupid mistake) but now i have had some help and we have rewired everything needed and redone all of the vaccum lines that where needed but now i am having trouble with it staying running we can pump the gas pedal about 2 times and it fires right up but unless we keep pumping the throtle the truck shut off we have managed to keep it running long enought to put a timing light on it and its in time. i bought most everything brand new for it except the carb i just rebuilt it. so some one please help me this is my everyday driver and i need it back on the road soon. thanks Michael. BTW it is a carbureted 351w
Bronc76
Have you checked to make sure choke is adjusted properly?
broncomichael
yea i did its electric choke and its working properly but if i unhook the choke and hold it almost shut the truck will stay running almost like its getting to much air
yo
Look thru this;
http://www.recarbco.com/technical/newtrouble.html
Start w/Cold Starting Problem
Then combine it w/Troubleshooting
Source: by thecarburetorshop.com
btw, Suggest you beg, boorow or buy a Vacuum Gauge and mont it in d cab or on/against dash
One of best Troubleshooting tools you'll ever get
In-Dash pic in an 83 Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
Vacuum Gauge Diagnosis - BEST!; Normal engine; Steady gauge 18"-20" at all speeds..." READ MUCH MORE Source: by Craig U at classictruckshop.com
broncomichael
yo
Look thru this;
Ok guys thanks so much for the help I will give it a try anythings worth trying at this point
eholt80
