86 Eddie Bauer Bronco
mjnort
I have a 86 bronco,headlights went out ? checked fuses wires etc. any suggestions....
Gunner
VA Beach, VA
bad wiring just like mine. my fix was to hot wire the switch and run wires from the switch to the headlights. you lose you high beams but it is a quick easy fix until you can get a new wiring harness.
M
mjnort
it was a headlight plug...was shorting out headlights
G
Guest_redneckpunk
Guest
i really dont know what is wrong with your truck but i do have a
1986 eddie bauer bronco for sale real cheap if your interested send me a e-mail
all my info is on my profile
Check lead from fuse to Hi Lo switch. If you have voltage at the switch and neither Hi or Low work, the switch may be bad.
You might also want to look at the modification at http:/www.bigbroncos.com for improving the voltage to the headlights by directly feeding them from the battery rather than thru the voltage distribution system for the whole truck. It is under technical information.
I did a variation of that proceedure by getting a plow light harness. Details if you want them.
Good luck, :)>-
fred tyler
