I agree with swampthing, with the proper mods you can build a beefy 8.8". In stock form, you'll want to look at the weak points if adding larger tires or more engine (like a 460 or sb stroker). The 8.8" axles attach to the diff with C-clips, weak point no. 1. The axle tubes are usually just spotwelded to the center section, weak point no. 2. If you're running a mild 302/351 V8, with tires no larger than 35's, all you may need is a decent limited slip.I've seen many of the factory-equipped Trak-lock's go out due to wear, but most of these are the originals. I've also seen a few broken teeth on the pinion gear. if you plan to run bigger tires or do that engine swap, then a Sterling 10.25" from an F-350 is a better axle. But there are lots of Jeeps and Explorers and other rigs running slightly modded 8.8" axles on the trails, JSM84
