78broncoBackuplights
Neldog
Does anybody know where the back up light switch is on a 78 ford bronco with 351m automatic ? I have read my haynes manual and cannot find the back up swsitch. I can only find the neutral safety switch. The safety switch works fine and I was told that the switch also worked the back up lights. Backup lights are not getting power on both sides.
Thanx Lee
swampthing
New Jersey
i know on my 88 250 the reverse lights are tied in with the neutral safety switch check there...use a test light put it in reverse see if you get power at the switch for reverse..if so start tracing wires there is a possibility on broken wire somewhere
79highrider
Frenchtown NJ
I had the same problem and fixed it by buying a set of $20 mini driving lights and mounting them on the rear bumper and wired them to a switch. Work as well as headlights for backing up and also fend off tailgators at night by flicking them on. :lol:
N
Neldog
I fixed my backup lights by replacing the neutral safety switch.
Thanx for the posts
swampthing
New Jersey
i've never had to replace any neutral safety switch.anytime i have a problem with reverse lights i check that first though to see if i can find the problem...and if i do have problems with the switch going bad we simply just bypass the switch. But i wouldnt imagine it costs much
N
Neldog
The switch cost me 46 dollars at autozone.
Thanx for your replies
figjeti
